2G Hard Start
jperks911
4
Mar 30, 2022
Ashby, Massachusetts
Hey guys i can not seem to figure out whats causing my hard start. The car will crank and crank and not start. Ive come to learn that most of the time if i jump the timing conectors in the engine bay the car will start. It's not the coolant temp sensor either. It's mostly on cold start up, usually once it's warmed it will start faster. I've been having this issue for quite some time now. Even after having it tuned I still had the issues. Any insight would be greatly appreciated! Thanks
Hey guys a little late to the reply but engine blew up again and I finally got the newly built engine installed. Here's a quick update I just figured out yesterday. I wasn't actually jumping the timing connecter. It was the fuel pump test conector that I was jumping. When it's cranking the cars only getting 8volts. If I add 12 volts to that connector when cranking var starts up.
The fuel pump rewire should have provided a high current feed to the pump. It isolates the MPI relay and check connector from the fuel pump if done correctly.
If your battery voltage is dropping to 8V during cranking I'd clean up all the power and ground connections and look into replacing the battery if it can't handle the load while cranking. You don't say in your profile but with the other mods I wouldn't be surprised if you were using a race battery.
And, as always, Please post a log from when it's having issues.
It's 4 gauge or 6 gauge wire from the engine bay to the trunk, stater wire is the same as factory, and fuse box is the same as factory. I have a power junction post in the engine bay underneath where the battery used to be to connect all the power.
4 Gauge is marginal at best due to the distance from the engine bay to the hatch. It's fine when your talking the distance from the alternator or starter to the battery in it's normal location. Your typical starter can draw 100A+ while turning the engine over. That will cause a voltage drop at your junction and if you don't have great chassis ground the drop increases.
For reference, I have a 2 gauge wire to the back just for the amps in my stereo and a matching set of ground wires (amp to chassis, firewall to battery, battery to block) That may be overkill but it's how to minimize voltage drops.
Anyway, assuming your power feed to the fuel pump relay comes from the battery and not from your junction you should have good poer to the pump and the power from the MPI fuel pump relay is only used to activate the rewire relay. If the voltage at the check connector in the engine bay is dropping to 8v it may not be enough to activate the rewire relay.
