hard SHIFTING tranny
whiteDSM
40
Oct 4, 2009
Prince, BC, Canada
Let me try to explain this the best I can!
-When I go from neutrel to first, it sometimes grinds (usually hard to get into gear)
-When I go from neurel to second to first, it's less likely to grind
-After cruising around in fifth for a while, it's extremely hard to get it into any gear
-Car is less likely to put up a fight if I jam it into gear fairly hard
i am also getting a whinning noise, dont know if it the tranny.
guessing low fluid? havnt yet checked but when i have i get around to it i will.
CAR ALSO has a short shift kit. (didnt install myself )
hmmm,
if you rev the car to 7k while in 1st, with the clutch depressed does the car stay still or creep forward a little?
if it is creeping forward then your clutch is dragging, and not fully disengaging
hmmm,
Havnt yet checked that, but i defiantly will. If this is the problem how do i fix it?
