half shaft removal
BayState300GT
67
Aug 22, 2008
Allston, Massachusetts
Ok so im about to pull my motor and i was wondering to remove the whole half shaft, do i need to remove the big hub/spindle nut in the middle of the spindle? Or should i remove the whole steering kunckle itsself?
You might find that after you've gotten the axle nut off, it's easier to push the axle back through the hub if you turn the steering wheel pretty dramatically. That way the joint in the axle can bend- it just gives you more clearance.
