Had new converter made
92awdgsx
487
17
Sep 16, 2002
Lincoln, Nebraska
This is the converter I had made. The side that mates to the motor is stock 10" mitsu, it tapers down to 7" on the side that goes in the tranny. Looks good, now I need to find out how it works.
Looks good. What is the reasoning for the 7" side? Higher stall, lower weight?
When are you going to give it a test run?
Reducing the size to 7" allows for higher stall. It should be somewhere around 6000-6500rpm. Still waiting on the input shaft to get done being made. I'm having a stronger one made with bigger and more splines for strength. I had the converter made with matching hub inside. I also had front and back anti balloon plates installed to compensate for all the torque, to keep the converter from ballooning.
Yeah, but I showed her how its used the correct way. :thumb: :D
What rpm is the car going to shift at?
Did you have the input hardened or is it a billet?
The car is going to be shifting at 11,000. The input shaft is made out of some special steel they had to order from England and it will be hardened.
