MHI Superhero
- 0
- Feb 26, 2008
Houston,
Texas
I just wondered if anyone knows the current HP record on the hacked 2G maf. I was told it is around 450whp.
Fake MAF + Use Map is probably the best feature on DSMlink. And when you say that people don't like it, what do you mean? Who? It works so perfectly that it's unbelievably easy. Have you activated this feature before on your car?A lot of people dont like that feature on dsmlink but that is how people are making that much power on the 2g maf. It doesnt work that great, because if it did people would use the 1g maf with dsmlink and have no issues, but thats not the case.
With dsmlink I would run a maf-t setup over the 2g maf anyday. The evo/3g mafs can handle all the power you can through at it, 600+whp has been proven on them. If you get to the point where the maf is an issue you can always go with a maf-t setup.
How about the GM mafs with Dsmlink? I heard originally they were a pain to use because they use different scales from mitsu mafs and no one had the compensation table perfected. However recently i've heard of alot of people using them with dsmlink. Do most people use them as blow through mafs? Is there alot to be gained from not having the maf on the inlet side?
