h3 bulb hid kit need help
Garrett95tsi
Jan 28, 2010
quakertown, Pennsylvania
i have the old style projectors non halos and they take h3 bulbs so i got an hid kit for h3 bulbs and I'm having a hard time trying to figure out how to install it
i need help these are supposed to be easy
H3 and H1 installs are the two that typically require some retrofit or modification. The wiring is simple in that you'll need to connect to ground and power. The bulb will need a way to be held in creatively using the OEM socket (drilled our or using a clip of some kind) or a total custom clip to hold it in there. Some people have used epoxy but it could come loose. It may void any warranty on the kit too.
  • Wanted 6 bolt NT water pipe
    • chrisman287
