gvr4 #975 rebuild
Bmxr152
579
May 27, 2006
Gardnerville, Nevada
So i purchased #975 about 3 weeks ago for $300 and since then have out 3k into including the registration that was $400. Car had 145k miles, rebuilt motor with 180 psi across the board, and arp studs and headgasket, and lots of work needed. It had no intake piping, mas, oil filter housing, injectors, belts, hoses, bad wheel bearings, wrong color body parts, blown suspension, no ac, no radiator or fans, improper battery relocation, no motor mount, and few other things which have all been since replaced.
I have also added some goodies...
BC 272 Cams
190lph pump with rewire
2x Pro form fans
560cc injectors
JDM rs fmic with 2.5 hardpiping after and 2" before IC
3" turboback with 3" high flow cat
Hot Bits Rally coilovers
SS braided brake lines
SS feed line
Ported Evo3
dejonTool MBC
DSMLink V3
Ported 2g manifold
Ported 2g O2 housing
I repainted the hood and fender, as well as repained the wheels silver. Here some pics so far...
wow good job on rebuilding the car from scratch, keep up the good work
Very nice, love it when someone rebuilds a GVR4, Good luck
nice rescue looks like you did a fine job, love those cars.
