GT35 Help!!!
dragon2144
74
Aug 16, 2008
East Moline, Illinois
Ok after my motor build I'm looking at upgrading to a GT35. I just have some things i need help with. Ok. Will it fit on a t3 manifold and where to buy a good one? Looking for a good O2 housing that will bolt to a stock like exhaust(VRS 3in. SS Turbo back exhaust). It is four bolt turbo side to the stock 2 bolt but if your helping you probably know that. Any one know where to buy one. Also How much House power could i expect? What Size of injectors would i need. Looking at maybe going E85 down the road. Have a way to tune so i can tune any injectors. Will i need to upgrade my fuel rail for the injectors? Ok. The big one. Should i go Journal Bearing or ball bearing. I know the ball bearing spools fast but i have heard the Journal Bearing turbo last a lot longer.
punishment racing makes a good manifold and o2 housing that will work. you need the 3" o2 housing if its a true gt35r and yes its t3. Hp is based on tuning and the size of the injectors and other mods. Ball bearing is the best way.
Ok thank you. Im looking at maybe about 450 to 500 hp as a goal.(Most likely more you know how that goes always want 100 more LOL will it make it and what size injectors would i need im probably going to look for a set of 1000cc injectors that way i have no worriers i can not give the fuel. I also thought of something else. Will i need a duel fuel pump set up for that big of injectors of will the one 255 be big enough?
I just installed that setup to my car. GT35r 70ar .63. Manifold I ran is ERL probably could get a good deal with TeamXXX. Rob hooked me up with the manifold. He is one of the vendors look him up. I got my turbo from ATPturbo.com Cool guy to deal with and will have everything you need to install that turbo to your car. I have 1000cc injectors which is ok for my setup but im not sure if it will be good enough for e85.
