GSX stock front sway bar?
Crawl
325
Jan 8, 2005
portland, Maine
Ok I thought GSX's came stock with front and rear sway bars, correct me if Im wrong. I jacked the car up and I cant find the front one, where is it located LOL. I see the back on just fine.
thanks in advance
its the only bar you will see that crosses the entire length of the car, it connects on both sides to the lower control arms. if you look behind the rotor its pretty easy to see the bracket that it connects to, do you have a haynes manual or anything i know in the front of the book it shows you an underside view of the engine and it will be pretty obvious for you. if you still cant find it let :thumb: me know and ill try to post a pic.
yeah I looked, im wondering if the moron that owned the car before me took it off or if perhaps my GSX didnt come with it because If there is a bar going all the way across its hidden... LOL
my fault i have an aftermarket one that hangs different, when looking under the car most of the bar will be hidden from direct view, but its still easy to see it connecting to the control arms. if you still cant find it stop by a local garage and ask them to look at it real quick costs nothing and only takes 10 minutes, or post a pick and ill circle it out for you, i have a 1g with an aftermarket bar or id post mine, maybe someone else on here can post a pic for us?
