Gsx Mechanic Near Miami,FL
xGsx
Apr 7, 2012
Miami, Florida
Hello Everyone i'm new to this. I Have a 1997 Mitsubishi Eclipse Gsx and i need to look for a mechanic near Miami, FL that is good with Dsm Motors and Knows how to do the electric part of the Engine. I need to do an engine swap and connect all the cables the way they are suppose to be connected, does anyone know of any mechanic that will help me for a good price near Miami, FL? Thanks.
If your doing a 6 bolt swap, it might be easier to swap in the engine harness and ecu with the 6bolt. That way no hacking of your currant harness, and its simple enough to do yourself. I live up in ft.lauderdale, ive never done a swap before but ive only worked on 6bolts, so I can help ya alone those lines
Thanks, what i actually need to do is the angle cam sensors. I tried to do it based off a guide online but it doesnt work.
Are you swaping s 6bolt motor or you're installing another 7bolt, you don't need a 1g wiring hardness if you doing a 6bolt swap go to the tech articles in here and you'll find all the info you need.
