GST/GSX Coilovers (Differences?)
VENOM
161
Apr 6, 2003
Rehoboth, Massachusetts
I was planning on doing a AWD conversion to my Spyder very soon, but not sure when I would be able to($$$). I do want to lower the car asap (before summer) planning on going with the Tein Type Flex setup once I do the AWD conversion. My question is, could I just get the GSX Tein TF now and they would fit or would there be fitment issues? I know the spring rate is different but that would be fine since I have a spyder. But I wasnt sure if the actual strut assembley had different bolt patterns etc. Any info would help. Thanks
jtmcinder said:
If you go here http://tein.com you will discover that the rates for FWD and AWD 2G Flex coilovers are the same.
- Jtoby
Ya I did go there and read that, Im a little slow and its takes me a while, but I wasnt sure if that was 100% that the shocks would fit, didnt see anything on that, saw the numbers. So you think they would fit then. Im just gonna call Tein direct, thanks for your help
I read that the GSX has a D38a body and the FWD has a D32a body? Now im guessing they won fit?
