gst fluid reservoir to rs
Do you have a rear hatch with a rear wiper already and all the parts? If your RS did not come with a REAR wiring HARNESS, then you will need to make one or cut one out. All you need few connectors for the wiper motor, Reservoir pump, and switch.
Well im doing the same mod. You will need all the pluming. On the turbo cars the fluid line runs from the res tank in the spare tire area down the right side of the interior,up to the right side of fire wall. Thier is a plug that will have to be removed and the gromet with the tubing put in its place. The power and ground wires will have to be leangthed and rerouted to the res. U will also need the filler tubing and filler gromet from the donor car. Pop out the plug on the left side hatch opening and replace with the gromet and filler tubing for the resavor. Every thing should be plug and play exept for the wiring.
Also if u dont have a rear wiper and the res has dual pumps then one of the pumps will have to be blocked off with somthing like a vacume tubing blocker or some thing else. So as not to fill your spare tire area with washer fluid.
I have searched the forums and haven't really found anything but this thread and this one http://www.dsmtuners.com/forums/appearance-interior-exterior/409499-adding-rear-wiper-arm.html
Has anyone completed this project?
Putting a Rear wiper into a RS?
I have a hatch from a GS on my RS along with the High Rise, but I want to make the rear wiper work.
I know I will need a few things such as ( Let me know if I missed anything! )
- Wiper / arm motor etc...
- Wiper switch
- Wire harness
- Wiper fluid that goes into the spare tire area
- Tube that connect to the Fluid
Im only doing because of my motor swap. The original washer resivor stopped me from running the srt throttle cable . I am not using a rear wiper on my car just deleting the 420a washer and going to a turbo style.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
