Grounding confusion
KtownDsm
Jun 24, 2007
Kenosha, Wisconsin
I just did the battery relocation but now I'm stuck. My question is, since I moved my battery to the back where do i connect all my new ground straps. I realize i have to ground them to the chassis but what parts of the motor would be the best to ground?
Intake manifold, the block, and the head. You can never have too many grounds. If it has a good mounting point on it, you should put a strap on it LOL. If your grounding it to the firewall or frame where there is some paint or its dirty make sure you clean it up first.
When it comes to wiring, You will find some pics of the factory grounding in this pic dump album.. hope it helps you in smoe way
