Grinding Noise from back of car
pradamike
109
Dec 15, 2003
eagan, Minnesota
Hey hows it going, when i am driving and i slow down to about 10-0mph and am breaking a little there is a grinding noise coming from teh back of my car it is harsh harsh metal on metal sound. then when i speed up u can hear it grinding.. i dont know if it could be my breaks or if something else is rubbing.. need help asap..
Take the rear wheels off the car, look at the rotors and see if there f*cked. Have you ever changed the rear pads before?
Your rear T-case could be going bad? CHeck the fluids maybe even change it, if you never have, its recommended every 50,000 miles. If you change it look at the plug (its a magnetic) it might have metal on it, if its alot that might be the problem.
Also look at the Drive shaft see if its rubing on the exhaust, this happened to me when I put my new exhaust on, I didn't postion it properly.
Hope this helps.
-Matt
