Grimmspeed MBC?
+3 for Hallman.
Not only is the Hallman proven and available in purple, you can also install -4 AN fittings for SS lines.
Order
The Grimmspeed MBC is an awesome item. Description says 4 clicks for every 1 lb of boost, in my experience it was closer to 5, but it was still very accurate once we figured that out. It acted absolutely identical to the Hallman on the dyno as far as holding boost. The boost curves were basically a mirror image. I ended up going with the Grimmspeed because they are local to me; only about 25 minutes from my house.
Maybe i just have a bad on or something but my hallman boost controller spikes a good 3-5psi if i floor it. My home made one which cost about 5 bucks to make doesn't have that issue.
