CDesigns
- 0
- Nov 15, 2004
Orlando,
Florida
I'm new on this board and I would like to share some good info for you greddy Profec B users, Now you can have the switching LOW/HIGH boost function easily:
The wireless switching kit from greddy cost around $100, and is a simple momentary switch but WIRELESS.
READ FIRST BEFORE MAKING THIS MOD.
If you plug a stereo headphone jack into the profec b II , you will have 3 wires comming out from the jack, one is GROUND , one is a 9volts source and the other one is a 3volts source that is the one that switch from LOW to HIGH boost when you momentary close the circuit with the ground wire.
Use a volmeter and check wich cable haves the 9volts source and discard that cable, and connect a Momentary push button switch on the other 2 cables .The 9volts source is to give power to the (greddy wireless switch) you don't need this cable.
THE SWITCH YOU'RE LOOKING FOR HAVES TO BE (Momentary push button switch that is normally open that it only connects when you pushed)
Here is the parts you need:
Stereo Headphone plug
http://www.radioshack.com/product.asp?catalog_name=CTLG&product_id=274-858
Momentary push button switch ( they come in differente sizes and colors)
http://www.radioshack.com/product.a..._name=CTLG_011_002_015_002&product_id=275-609
ENJOY YOUR BOOST
ENJOY YOUR BOOST
i happen to have a cable layin around and a momentary switch, so i gave it a wirl and what do ya know works awsome!! now to mount it by the shifter for convenience!!
