Greddy E-01 boost controller problem need help??
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
Got my greddy E01 boost controller installed, but i set it to 15psi and it stays at 10psi till about 5k then goes to 15-17?? anyone know how to set this thing up??
thanks
Is your boost of 15psi for the high or low setting bc from that last pic it seems like you are using the speed function to control the change from low to high boost. I have the E-01 aswell but my car has been broken for 5 months so kinda forgot how to work it. I had mine set the same boost across the board and when I pushed the knob it would switch to the high setting.
15psi is at low setting why?? no i go to the high low setting and either choose hi,low,or off???
Well you can use the function of using low boost till a certain speed or rpm and then change to high boost so that you can get better traction and then if you push the knob it would go to overtake boost. But I am sure you know this. I don't know why your boost fluctuates BC mine stays were I set it at, sorry that I can not be more help.
