Got codes from CEL need help
I think that's coolant temp sensor, which I suggested you take a look at in your other thread.
there are two sensors the temp is in the bottom of the radiator next to the bottom hose and the other is in the coolant resivior...but i think that one is just a level sensor...
your right. the CTS that your going to want to look at directly is the one on the radiator. but just because it throws a CTS code doesnt mean go and change the sensor... it might have a million other things it could be other than the sensor
Makes sense if my car is cold then i have a fuel trim issue. When you say directly on the radiator are you referring to 218dsm's comment to the bottom or the top?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
