VelocitàPaola
Moderator
- 5,130
- 207
- Jun 14, 2005
Ft. Lauderdale,
Florida
You can measure the diameter of the disk to determine its calibration. I believe the 12:1 disk is 2.72", though you can go to Vortech's website or call them to confirm.
I doubt the size of the vacuum line would cause this problem; the AFPR is actuated on pressure, not airflow. Pressure acts on all points in a system equally*: if the manifold is under 8psi of pressure, so is the PCV valve and the FPR. The hose diameter would have to be extraordinarily small before you saw unusual behavior.
Like Ryan said, just make sure there are no kinks or tears in any of the vacuum lines.
*There are caveats to this statement, so don't inundate me with critiques. Non-Newtonian fluids and compressible fluids act differently. At lower pressures and velocities, though, air behaves similarly enough to a compressible fluid.
I also havent updated my profile info for awhile so it's not perfect. I'll do that now
