Gm Translator Question?
talonsteve25
247
Jun 21, 2008
calgary, AB, Canada
Holy crap i did so much searching that my head is spinning but found nothing, i bought a translator and maf today but it has a 1G plug and my car is a 2G what is the wiring order to hard wire it in? And how could i tell what version i have to determine how to set mine? Thanks
Steve
I believe the Maf-Ts v1 are 1g/2g specific. The Gen2 can be used on 1g or 2g as well as a few different mafs.
If you bought a v1, it may be useless to you.
Also the maft is notorious for a wandering tune. Unless you're making 500whp+, the 2g or evo8 mas will work just fine.
I bought a maft, sold it for an evo 8 maf and still have money for the intake pipe.
well is there a way i could i tell which version it is? and i plan to run big numbers so i most likely will benift from it in the long run.
They should say on the box what version they are.
Mafts work like safcs in the fact that they "hide" airflow from the ecu, so are really only usable to 650cc injectors without a custom eprom.
