GHS GXS- Cylinders 2&3 dead, but why...?
gijoe985
562
20
Dec 13, 2007
Grandview, Washington
Hello All,
I wanted to make a new thread for a new problem.
You can follow some of our old stuff HERE
Current situation-
6bolt block, 2ga head, DSMlink v2.
When the car is running (1500rpm is where it stays), I can pull the injector harness off for cylinders 2 or 3 with little to no change in the operation of the engine. RMPs stay constant.
We have verified timing (though tomorrow I will check that yet again)
Swapped inner with outer injectors with no change.
Noid light shows signal to the injectors.
We have spark at each cylinder.
We have 160psi of compression on all 4 cylinders.
I think I've covered my "why doesn't my engine work 101" bases.
Thoughts?
Have you had the injectors flow tested? I would ohm them out and see if there in spec. Ive read some of your past threads, if its been sitting for long, the gas is probably not the best and maybe some junk in the lines clogged up injectors 2 and 3 is my guess.
How did you test spark? Light or did you actually pull a plug and have a look? After cranking pull the plugs and smell them. All 4. Which ones smell like gas? If 2 and 3 smell like gas I'd say injectors are working but spark isn't. Alternately if they don't smell like gas and you verify spark the noid light may not be telling you everything.
The problem is when we swapped the #2&3 with the 1&4, the scenario was the exact same. So, regardless of flow, that should eliminate a totally plugged injector.
I actually pulled the plug wire and watched it spark. And I compared the spark on 2&3 with #4 and they all looked equally powerful.
True point that the noid light could be giving us a weird signal. But it all looks the same across the board. I wonder if swapping the #2 and #3 injector wires would make any difference at all?
Maybe it's just fouled spark plugs in those cylinders! I know I have seen spark plugs foul out, yet not look fouled. We could try swapping plugs...
Did you use a 1g cam angle sensor and wire it up right? Because the 6 bolt block doesn't have a crank sensor as far as i remember. Some one correct me if im wrong.
We have a Kiggly Racing crank sensor on it. So that is solved.
I sitll say smell it. See if you're actually getting fuel in 2 and 3. Longshot but did you check the valve actuation for those cylinders? Missing or broken lifter/rocker? Quick visual would tell you that everything is opening. Given we have waste spark with 1/4 and 2/3 being pairs did you ohm out the coil on 2 and 3? Lastly have you checked the ignition module? I've seen those give trouble with one or both pairs of coils. Multimeter should point you in the right direction quickly.
