92 Eclipse N/A 2 dead cylinders!!!!!
cowboy65605
Feb 28, 2011
aurora, Missouri
Hey everybody. I picked up a new 92 Eclipse 2.0 4g63 N/A 5 speed for bout 300 bucks from a friend. When I first got the car it wouldnt even crank over. I replaced the ECU and now I have crank. Then when it still wouldnt start I checked and i have fire in cylinders 1 and 4 but 2 and 3 are dead. I replaced plugs and wires and it didnt help. Now I have replaced the Coil, still dead as can be. I have a buddy whos a dsm-er and he said an what he called an igniton module (power disturbiter) the small chip that sits on the intake directly under the coil behind the timing belt cover. I would like to know if anyone else has ever had this problem with thier 2.0 before, if so... HOW DID YOU FIX IT!!!!!!??? its kind of getting on my nerves cause i have a turbo kit for it but I want to make sure that Im not just gonna waste my time putting the turbo system on it for nothing if I cant figure out why I have no fire to 2/3. Please help!!!
from what you described its possible that the power transistor pack has burnt out... check to see if you have a voltage signal at pin 1(cylinder 2 and 3).. pin 8 is cylinders 1 and 4 so you can compare the difference between the two.. this should be the problem if the wiring and the coil have been replaced
thats what i was thinking anyway. thank you none the less. this is my first 2.0. i dont want to get rid of this car, its pretty nice. i felt like i stole it. its perfect condition, except for a lil bad paint.
