Get me back to boost! Build Part 2
atruepretense
166
Jul 15, 2009
Bethlehem, Pennsylvania
So, a little update on the status of the DSM. I already have most of the stuff removed on the engine. All that is left is to unbolt the trans, and motor mounts, and cross member. Once that's done the engine is coming up.
My girlfriend's bro is a big DSM fan also, and has helped me out a great deal by selling me a 7 Bolt bottom end that is in great condition. Pistons, rods, crank, everything. I'm paying $250 for that, and bringing her home to rebuild the bottom end. As soon as I have a bit more cash this week, i'll be sending out for some ACL rod and main bearings, ARP rod bolts, and head studs, and a few other things like a new lower timing cover because mine broke. :ohdamn:
When I put on the new head, I put a new head gasket, water pump, and timing belt and balance belt. Won't need the balance belt anymore since the block i'm getting has them blocked off. Hello 15lbs of rational mass gone!
Will also be checking the clutch and pressure plate tomorrow for wear to make sure I can still use it. Will post some more details tomorrow.
I'm attaching a pic of what I found on the rod cap of cylinder #1, and a video of it. There was NO bearing left. :notgood: And it dug a nice gouge in the rod cap.
http://www.youtube.com/watch?v=RcMfKWBUeOk
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
