Gaskets for 16g and FMIC
cdg7
43
Oct 17, 2012
minneapolis, Minnesota
I ordered a used 16g but am i going to need one of these: Forced Performance Turbochargers: Mitsubishi DSM Turbine Housing Outlet Gaskets
I don't know what it's for but if I need it I should buy one.
Also my new FMIC is leaking boost where the pipe connects to the intake manifold. is there supposed to be a gasket or something there? if so, what's it called? i didn't see anything in the DSM manual
That gasket is the gasket between the turbine housing and 02 Housing. Usually you should replace these types of gaskets when you take apart/reassemble turbo related gaskets. They compress when tightened for a solid seal.
Where the upper intercooler pipe meets the throttle body, you should look for an OEM throttle body gasket, that way it will seal the pressurized air entering the throttle body.
  • Wanted 6 bolt NT water pipe
    • chrisman287
