16g install kit for VRSF FMIC
cdg7
43
Oct 17, 2012
minneapolis, Minnesota
Will the ExtremePSI 16g install kit work for the VRSF FMIC? I read in alot of threads that the FP kit won't work since the pipe faces the wrong way. Also read the VRSF pipe has a really tight bend and is hard to work with...
I'd rather not get a VRSF pipe AND an install kit. Those of you running the VRSF FMIC, which one did you guys use? FP? ExtremePSI?
You have to use the pipe vrsf sells, the vendor that sells those kits wrote on another thread that it angles 6 degrees further to the right than normal ones. Why not just piece together what you need for the install instead of buying a kit - then you only have to buy one pipe
One thread said that the VRSF pipe was hard to work with and didn't seal good otherwise I would. The bend was also too much to get it tight or something
