1G gas tank & hose
slvrbllt
159
Jan 17, 2009
a city in, New Jersey
Until rcently I had not realized, I has a hole in my gas hose on my 92n/t laser. The hose that connectes the gas tank to the tube where you pump gas in. I went to the junk yard to just get the hose. That hose was stuck in there!! Do I need a tool to get the hose out or is it the I chose a car with the hose stuck on there. My car is in the garage for other reasons so I should just fix this but dont know how to go at it. This may seem like a noob question but I just want to fix that hose asap
The hose is stuck on the pipe from being so old. If possible squirt some WD-40 (or equivalent) into the ends of the hose to try and loosen that seal. Once the clamps are removed, TWIST the hose where it meets the pipe, do not pull, and it should eventually break lose.
on the hose I tried to take off I used wd40 but it was jammed in there
I will look for another dsm and try with another gas line
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
