Gas leak in fuel pump assembly.
popwarbunny111
44
Aug 24, 2008
indianapolis, Indiana
I have a 1990 Mitsubishi Eclipse GSX. My Fuel pump is in the trunk of the vehicle.
Well when i put it back in from taking it out. I tried to start it and i now have a leak in my fuel
line on the assembly part. Will JB weld work to fix the leak? :sosad:
Jb weld will work,(been there)but lot's of companies rebuild them for cheap.I just got one back and for 40 bucks,sandblasted, new extended lines welded in and painted.It looked like brand new.The place was a radiater specality shop.
I cut mine off, drilled it out and put in a bulkhead.. But I also replaced the fuel lines and put in two 255's at the time... Just find a used one if you're not going all out with it.
