ulitka
151
12
Apr 9, 2009
Raleigh, North Carolina
Parting out 98 GSX Eclipse. It was a project weekend car.
I will be adding more parts to this thread.
Prices include paypal fees.
Prices do not include shipping.
Shipping to Canada, HI, PR will cost extra.
1. ECM Link V3 speed density. SOLD!!!
- EPROM ECU was purchased from ECM
- GM IAT, 4-bar MAP sensors and wires are included
2. Transmission Shep stage4 build. SOLD!!!
- Taller 1st gear
- shep spec 2nd gear
- EVO 3rd and 4th gears
- Taller 5th EVO gear
- double syncro all gears
- race spec preloads
- temperature prob fitting provisioned in front of transmission case for Glowshift transmission temp gauge. Gauge and probe are included.
* -6AN male fittings on drain plug and top of the case above 3rd/4th
hub/slider gears. Tilton gear oil pump picks up hot oil, moves it through a small cooler, and returns cooled gear oil on top of 3rd/4th hub/slider. Must have mod for high torque engines. I can include the pump, hoses, cooler for additional $130 with purchase of the transmission
I still have the shipping box from Shep.
3. TCE Wilwood brakes front and rear. SOLD!!!
- 6 pistons front calipers
- 4 pistons rear calipers
- Vented slotted Wilwood disk rotors
- Front aluminum disk hats
- Rear disks retain parking brakes
- SS brake lines
4. Engine block 7 bolt. SOLD!!!
- This block was not assembled since it was professionally refreshed by a machine shop.
- decked, honed, cleaned, inspected, all standard values.
- cylinders were never bored over. After honing cylinders retain standard values.
- I have this block winterized sealed. Pictures may show streaks on a deck from fogging oil and plastic bag.
5. Rear differential with KAAZ LSD. SOLD!!!
- KAAZ LSD is a beefed up version with clutch and plates
- LSD performance can be tuned based on configuration of clutch and plates.
- Only KAAZ gear oil was used
- At the time of LSD installation, bearings and seals were replaced, preloads, gears mesh, and free play adjusted to match service manual values.
- Differential is for none LSD axles only.
6. PTE 6262 DBB turbo T3 0.82 A/R, 4" compressor cover. SOLD!!!
- I purchased this turbo new from www.extremepsi.com
- Dual ceramic ball bearings oil cooled
- Only Amsoil Dominator 15W50 engine racing oil was used
- 2.5" v-band exhaust outlet
7. Boomba Throttle body with Evo TPS. SOLD!!!
- TB elbow is 2.5" with Tial QR BOV flange
- AIT GM bung for speed density setup
- 3" flange is included
- Adapter plate must be for EVO intake manifold
- Adapter flange for EVO ISC motor
- ISC motor is included but may need to be replaced
8. JMF Drag Intake manifold for 2G head. SOLD!!!
- Has lots of vacuum fittings
- Flange for Boomba throttle body
9. FIC 2150 injectors. SOLD!!!
- New set of O-rings
- injectors include pigtails and DSM adapters
- injectors have a thermal tape wrapped around them to reduce heat soak
10. Full Race T3 exhaust manifold. SOLD!!!
- flanged for 2G head
- v-band for tial wastegate
- fully wrapped with a heat wrap
- v-band flange clears radiator
11. Tial waste gate MV-R water cooled. SOLD!!!
- Waste gate was water cooled
- I may have a brand new diaphragm. Will include it if find it.
12. DEI T3 turbo blanket. SOLD!!!
13. O2 housing 2.5" V-Band. SOLD!!!
- SS v-band flanges TIG welded to SS pipe
- Heat wrapped
- v-band clamps are included
14. SS v-band down pipe. SOLD!!!
- 2.5" v-band inlet transitions to 3"
- 3" v-band outlet
- flex section
- 2 O2 bungs for wide band and OEM O2 sensors
- bung for EGT sensor
- heat wrapped
15. FIC Aluminum anodized high volume fuel rail. SOLD!!!
- 8AN male inlet
- 6AN male outlet
- wrapped with heat tape to reduce heat soak
- 8AN hose inlet hose included
16. Bosh fuel 044 fuel pump. SOLD!!!
17. D2 coilovers. SOLD!!!
- 36 levels of rebound adjustments
- adjustable height and spring preloads
18. 2G built head. SOLD!!!
- head was not assembled after machine shop decked, cut valve seats, replaced guides, pressure tested for valve leaks.
- 1mm oversized new valves
- 5 angle valve job
- New valve guides
- New valve steam oil seals
- Kiggly HLC
- New lash adjuster (OEM in sealed packages. Purchased from TMZ Performance)
- EVO rocker arms
- Kiggly beehive springs and titanium retainers
- Manley valve retainers
- light porting and polish of intake, exhaust ports.
- Polished chambers
19. Kelford 280 cam shafts. SOLD!!!
20. Fidanza adjustable cam gears. SOLD!!!
21. ETS 3" FMIC short route $325
https://www.extremeturbosystems.com/...CABEgJX3PD_BwE
http://s883.photobucket.com/user/uli...ary/ETS%20FMIC
22. NRG steering wheel with quick disconnect. SOLD!!!
23. OEM heavy weighted leather shift knob. SOLD!!!
24. CAT back custom V-Band 3" exhaust. CAT (hollow) is included. Price $500
- Vibrant SS pipes, v-bands, muffler (has AMS logon on it)
- TIG welded
NOTE: down pipe and O2 housing are not included.
http://s883.photobucket.com/user/uli...Band%20exhaust
25. Intercooler short route piping kit. Price $180
- Vibrant couplers and clamps
- Water injection bungs (plugged)
- 2/5" aluminum piping is from turbo compressor outlet to FMIC inlet, then from FMIC outlet to throttle body elbow.
NOTE: Intercooler, FMIC, throttle body elbow, throttle body, intake manifold, and water injection nozzle are not included.
http://s883.photobucket.com/user/uli...%20Route%20Kit
26. Jay Racing Alternator Relocation kit and Saturn Self Exciting Alternator. SOLD!!!
27. Tial QR BOV with spare diaphragm/piston. Price $170
http://s883.photobucket.com/user/uli...ial%20QR%20BOV
28. Snow Performance Water/Meth injection gas stage 3 kit. SOLD!!!
- Comes with different size nozzles
- Dual Nozzle Upgrade
- Check valve nozzle holder
29. Corbeau FX1 Pro racing seat with bracket and 5 point harness. Price $300
https://www.racing-seats-usa.com/cor...lter=undefined
http://s883.photobucket.com/user/uli...u%20FX1%20seat
30. QuarterMaster Gear Drive Twin Disk Clutch for 7 bolt AWD. SOLD!!!
- Purchased from TMZ Performance
- Racing 6 puck clutch disks
- Flywheel has a ring gear for AWD starter
- Hub is for OEM TX input shaft
- It has less than 12 launches at drag strip
- Normal driving clutch engagement is much smoother now compared when it was brand new
- Must have for those who need to shift in higher RPM range
31. Stock ECU from 98 GSX 5 speed. SOLD!!!
32. Auto Gauge Tachometer with shift light. Price $50
http://s883.photobucket.com/user/uli...0shift%20light
33. Cold Air Intake Forced Performance Intake pipe and K&N Filter. SOLD!!!
- Filter routes into fender/bumper lower area
- FP pipe connects to a 4" turbo compressor cover
- FP pipe has 3 barb fittings for catch can tubes
- High quality Vibrant and FP silicone couplers
34. Modified fuel sending unit with Jay Racing 342 fuel pump. SOLD!!!
- With this setup you will be able to run a true 6AN hose from tank to aftermarket fuel filter and to fuel rail
- New sack pre-filter
- 10 gauge wires connected to fuel pump
- 6AN male bulk fitting connected to pump's outlet
- 10 gauge wires were connected to a external relay, fuse, and to the battery
- Some splicing to stock wiring harness will be required
35. Stainless Steel dump pipe for Tial MV-R wastegate. SOLD!!!
- Tig welded flange
36. ARP Head Studs Custom Age 625+. SOLD!!!
- nuts were torqued to 100ft/lbs
37. VIS Racing Carbon Fiber G Speed Hood for 2G. SOLD!!!
- Hood is outfitted with AEROCATCH Xtreme Series flush mount hood latches with locks and keys
- Hood pins are mounted to aluminum brackets and radiator support bolts.
37. Fluidampr Street Series Harmonic Damper. SOLD!!!
38. Flex-A-Lite 12" electric fan with powerful 30190 motor @ 9.50 amps with thermostat control. SOLD!!!
39. OEM ignition coils. SOLD!!!
40. Ingersoll Boost Controller. Price $40
- Includes bracket and barb fittings
http://s883.photobucket.com/user/ulitka/library/Boost controller
Lots of items sold. Listing updated.
Thank you.
Many items sold. Still many left to sell. I have OEM parts unlisted, let me know if you need something specific. Thank you.
Rolling shell is available for sale. See pictures. SOLD!!!
Few items are still for sale.
Dropped prices and updated items sold.
