Galant VR4 1991
Summit White Galant VR4 with some "spice" (kustom exhaust piping cause welders around here suck) *looking for good welder
They were random offroad led lights that I found at runnings if you have one of those stores, if not you can find them online they are pretty cheap. The size is 4 inches and they are really bright but my passenger side one is on the fritz currently. All you do is splice them into the current wires and they work great.
Kind of, you got to play with the metal a little due to if you just mount them straight on to the old mount points it doesn't fit exactly (It would be too low). I went ahead and bent the existing ones and mounted the mounts it comes with and filled it in with a coating to make sure it doesn't rust or anything. But it isn't really hard to do.
