ToughTalon
- 89
- 0
- Jun 2, 2004
Columbus,
Ohio
I thought I would post this for people because I hear about a lot of people using heads that have previously had bent valves. I should have made the title of the thread "FYI for people re-using heads with bent valves". I recently re-built and did a mild port job on a head that had bent valves.
Much to my suprise the bent valves cracked 5 of the 16 valve guides. I have been wrenching on DSMs for years and this was a new one to me, so for noobs and not-so-noobs always keep the valve guides in mind if you bend valves or re-use a head that had bent valves. I doubt the vavle guide would break but its still scary to think about.
I didnt post a pic with this because after the head was cleaned and I removed the valves, the cracked valve guides were obvious.
