fwd tranny in an awd shell?
stace
86
16
May 27, 2008
Belleville, ON, Canada
I got a 92 awd auto with a bad tranny, started to hesitate when i pressed the gas pedal, now it barely will move till 4000rpms, with boost! Same in reverse.
Im giving up on it, and I cant seem to find a 1g awd auto tranny.
I can get a 90 or 91 fwd auto transmission and any stock parts off that car.
I assume I can swap the fwd onto the 92, but what all do I need?, Which TC should I use, axles, TCU, harness?
This is just till I can get a awd, or rebiuld mine.
BTW the doner car is a non turbo 2.0l
Are you asking what "parts" you need to swap the FWD auto trans into the AWD auto shell? I'm a bit confused...
The 1g auto's are grouped like the manuals. Different half shafts, but the other stuff is the same. If you need more info try contacting foreign muscle (they have a website too). They are good with 1g auto stuff.
what parts off the 91 non turbo fwd do i need to put the non turbo fwd tranny in the 92 awd shell?
