FWD to AWD brake conversion.
slider85
469
May 21, 2004
Langley,
ok. 93 FWD NA, can I change my calipers and rotors to the 2-piston AWD calipers? If so, what are all of the components I would need? please list everything, rotors, calipers, brackets, hoses, etc.
Also, if I bought some slotted rotors to go with the AWD calipers, I would obviously order the rotors for a Turbo, AWD car, right? Finally, is there a difference in the brake lines between the NA and Turbo AWD models, like fittings or anything? Because I would want to get SS lines as well.
I did this to my brother-in-laws car you need the carrage bracket, the caliper, the 11" rotors and you may as well get ss lines also I had to put washers between the carrage and the hub because when you tighten the carrage bolts down they pull the rotor tward the engine bay and then they wont spin. It's really easy to do.
all you will need is the calipers themselves the bracket calipers bolt to and the rotors.
the dsmers here always use the Big Brakes from thec Mitsubishi Diamante v6..the bolt up too( any 89-94 diamante v6)
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
