2G FWD brake mild upgrade questions
starscreem
128
May 2, 2005
hoffman estates, Illinois
just like it says guys i have a couple questions. first off i have a 95 gst with single piston calipers. i want to get duel pistons from napa that are oem for the gsx, do i need a speacil braket to put these on or will they bolt up for me. i do no i will need a set of gsx rotors is that only in the frount or in the back to
thanks guys
matt
heres a link to them to ------http://napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=SDC&PartNumber=24264021&Description=Brake+Caliper+w%2f+Hardware+-+Left+Front+(Semi-Loaded)+-+Remfd
If that caliper really is what they sell you then no those won't just bolt up because they are missing the mounting bracket.
You also will need the correct 265mm rotors ust like it says on the VFAQ page.
http://www.vfaq.com/mods/BigBrakesInfo.html
Steve
