2G Full Blown Dual Fuel Pump Hanger Instructions?
JCL84
110
5
Jun 13, 2012
McHenry, Illinois
I will be installing this on my 2g GSX soon but I do not have any instructions on how to install this thing. I tried sending a email to Full Blown for instructions but I didn't get a response. I found detailed instructions on the Evo Forum by Full Blown for installation but I am not sure if these instructions would be the same for my car. Here is the link... http://forums.evolutionm.net/evo-engine-turbo-drivetrain/240268-twin-pump-install-pics.html
Is the wiring the same for the fuel pump on the evo's and the 2g or is it different?
wouldn't it be easier to put one in the tank, and then have an external one. How much power are you planning on making, that a single pump in the tank would not support? I'm not even sure if you could get two pumps on a single hanger to go through the hole in the top of the tank, then you have to have a second fuel line, I would think ?? Good luck with your project.
It will fit. Its made for a 2g and I thought about going to a single pump but then I would have to sell this set up to afford a OEM fuel pump hanger since I don't have one. Also the way this thing is set up I only need one feed line. I'm trying to make 400hp with my current setup. I plan on going bigger later so it might be worth keeping this dual pump hanger.
