2G Full Blown dual hanger installation
twilcox62285
Feb 15, 2024
Commercial point, Ohio
Hi there I have a 98 GSX with a 6 bolt swap and a laundry list of after market parts. I recently purchased a Full Blown dual hanger with 2 AEM 340 LPH pumps. As far as the wiring goes how do install the wiring on factory connectors?
I currently have a rewire kit on the current setup do you happen to know the part number for the bigger relay than the standard relay
AEM says that each pump should be fused for 20A and that the current draw @ 80 PSI is 15A @ 13.5V. So, you need to use a relay (and wiring to the relay) that can handle at least 40A and be fused at the battery for that in addition to the fuses feeding the pump.
A relay is just a remote switch. You can use one the size of a brick if you want to.
I use the Stinger SGP38 with the largest wire possible.
