fuel tuning
The sAFC is VERY easy to use. Will show your gas for each 1000x RPM, and then you just simply hit the up or down arrow if you want more or less fuel :thumb:
Well I don't know if 350whp is considered high horsepower, but it definately works fine for me!
Yup no problem. I have the sAFC I (the older one) but the II and Neo work just the same. You can set a "high throttle" and "low throttle" mode, set the fuel for each, monitor various things, and they make kits to mount it pretty much everywhere. :thumb:
