fuel trims not moving
wishful_laser
242
Nov 25, 2003
springtown, Texas
i noticed my fuel trims dont move at all. i am a newbie at this and i think it is running rich. my trims are at 81% and dont move at all. let me know what you guys think of my logs.
sorry so sloppy but i havent figured out how to take them off the plviewer in a format that the post can read. what do you guys think?i will do another run with lower boost so i can actually get to the redline. i am running about 15 psi but it is rather cold here in tx. i will be getting bigger injectors and the afpr really soon.
not yet but i thought that if the 02 cycled at idle and ended up at .9-.94 at wot that it would be working just fine. my log shows it to go from a .9-.92 at wot.(1g)could i be runner extremely rich? (80%-120% on a 1g) mine stays at the max low(81%) on all three fuel trims. according to the pocketlogger hints that would mean that im running really rich.my 02 trim cycles from 100% at wot to 117%then down to like 60% when i left completely off the gas.let me know what you guys think.how many of you running the gm maf actually still has the lower honeycomb. mine still does and i read that if you take it out it would lean out the entire fuel map.possilblly fixin my prob but i dont want to do it if it isnt going to do n e thing.
two things: i dont yet have an afpr(i will be getting very soon) how do i check my fuel pressure without the afpr gauge? and second, it s not just my low trim. its low,med, and high. my o2 trim is fine.i also made another log today but i havent figured out how to put it on here. i tried the same thing i did before but i guess im missing something. n e way, my knock went up to like 17,my timing hit an all time low of 10, and im still getting fuel cut. could the afpr fix all these probs? n e info on the honeycomb removal on the gm maf?
Unless you are running alot of IDC you could still be overrunning the FPR... Even in the mid and upper rpms.
The base fuel pressure + boost is actualy
higer than normal but fluctuating + boost so it is'nt consistant.
my idc goes up to about 90-95% at wot. i know i will need bigger injectors but i have to wait for the funds to come in. what about the lower honeycomb on the gm maf? remove or not remove. hom many of you guys are running without it. i will be getting my injectors and the afpr at the same time. i am also going to get the ss line kit to go with it. i also thought about getting the electrical fuel pressure gauge so that i can mount the gauge itself inside the car. kinda expensive but i figured that is one of the most important gauges to have. let me know what you guys think.
Try this again...
<div id="fuel cut@5500_10904" align=center x:publishsource="Excel"><object id="fuel cut@5500_10904_WebCalc" codebase="file:msowc.cab" classid="CLSID:0002E510-0000-0000-C000-000000000046"><param name=DisplayTitleBar value=false><param name=ViewableRange value="$A$1:$K$30"> <param name=DataType value=HTMLData> <param name=HTMLData value="&lt;html xmlns:v=&quot;urn:schemas-microsoft-com:vml&quot;xmlnsOMG=&quot;urn:schemas-microsoft-comOMGfficeOMGffice&quot;xmlns:x=&quot;urn:schemas-microsoft-comOMGffice:excel&quot;xmlns=&quot;http://www.w3.org/TR/REC-html40&quot;&gt;&lt;head&gt;&lt;style id=&quot;fuel cut@5500_10904_Styles&quot;&gt;&lt;!--table {mso-displayed-decimal-separator:&quot;\.&quot;; mso-displayed-thousand-separator:&quot;\,&quot;;}tr {mso-height-source:auto;}col {mso-width-source:auto;}br {mso-data-placement:same-cell;}.xl15 {mso-style-parent:style0; color:windowtext; font-size:10.0pt; font-weight:400; font-style:normal; text-decoration:none; font-family:Arial; mso-generic-font-family:auto; mso-font-charset:0; mso-number-format:General; text-align:general; vertical-align:bottom; border:none; mso-background-source:auto; mso-pattern:auto; mso-protection:locked visible; white-space:nowrap; mso-rotate:0;}.xl22 {mso-style-parent:style0; color:windowtext; font-size:10.0pt; font-weight:400; font-style:normal; text-decoration:none; font-family:Arial; mso-generic-font-family:auto; mso-font-charset:0; mso-number-format:&quot;mm\:ss\.0&quot;; text-align:general; vertical-align:bottom; border:none; mso-background-source:auto; mso-pattern:auto; mso-protection:locked visible; white-space:nowrap; mso-rotate:0;}--&gt;&lt;/style&gt;&lt;/head&gt;&lt;body&gt;&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;x:ExcelWorkbook&gt; &lt;x:SpreadsheetAutoFit/&gt; &lt;x:MaxHeight&gt;80%&lt;/x:MaxHeight&gt; &lt;x:MaxWidth&gt;80%&lt;/x:MaxWidth&gt; &lt;x:ExcelWorksheets&gt; &lt;x:ExcelWorksheet&gt; &lt;x:WorksheetOptions&gt; &lt;x:TopRowVisible&gt;0&lt;/x:TopRowVisible&gt; &lt;x:LeftColumnVisible&gt;0&lt;/x:LeftColumnVisible&gt; &lt;x:protectContents&gt;False&lt;/x:protectContents&gt; &lt;x:protectObjects&gt;False&lt;/x:protectObjects&gt; &lt;x:protectScenarios&gt;False&lt;/x:protectScenarios&gt; &lt;/x:WorksheetOptions&gt; &lt;/x:ExcelWorksheet&gt; &lt;/x:ExcelWorksheets&gt; &lt;/x:ExcelWorkbook&gt;&lt;/xml&gt;&lt;![endif]--&gt;&lt;table x:str border=0 cellpadding=0 cellspacing=0 width=704 style='border-collapse: collapse;table-layout:fixed;width:528pt'&gt; &lt;col width=64 span=11 style='width:48pt'&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl15 colspan=3 width=192 style='mso-ignore:colspan;width:144pt'&gt;1/14/05-16:00:34 - GFMS&lt;/td&gt; &lt;td class=xl15 width=64 style='width:48pt'&gt;&lt;/td&gt; &lt;td class=xl15 width=64 style='width:48pt'&gt;&lt;/td&gt; &lt;td class=xl15 width=64 style='width:48pt'&gt;&lt;/td&gt; &lt;td class=xl15 width=64 style='width:48pt'&gt;&lt;/td&gt; &lt;td class=xl15 width=64 style='width:48pt'&gt;&lt;/td&gt; &lt;td class=xl15 width=64 style='width:48pt'&gt;&lt;/td&gt; &lt;td class=xl15 width=64 style='width:48pt'&gt;&lt;/td&gt; &lt;td class=xl15 width=64 style='width:48pt'&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl15&gt;Time&lt;/td&gt; &lt;td class=xl15&gt;RPM&lt;/td&gt; &lt;td class=xl15&gt;Knock&lt;/td&gt; &lt;td class=xl15&gt;Timing&lt;/td&gt; &lt;td class=xl15&gt;O2&lt;/td&gt; &lt;td class=xl15&gt;Inj P/W&lt;/td&gt; &lt;td class=xl15&gt;O2 Trim&lt;/td&gt; &lt;td class=xl15&gt;Fuel Trim &lt;span style='display:none'&gt;High&lt;/span&gt;&lt;/td&gt; &lt;td class=xl15&gt;Fuel Trim &lt;span style='display:none'&gt;Mid&lt;/span&gt;&lt;/td&gt; &lt;td class=xl15&gt;Fuel Trim &lt;span style='display:none'&gt;Low&lt;/span&gt;&lt;/td&gt; &lt;td class=xl15&gt;Inj D/C&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;2.1990740740740739E-6&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;2563&quot;&gt;lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;10.769&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;23&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;4.3981481481481478E-6&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;2656&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;12.051&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;26.67&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;6.7129629629629622E-6&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;2719&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;12.307&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;27.89&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;8.9120370370370373E-6&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;2781&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;16&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;13.076000000000001&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;30.3&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;1.1226851851851852E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;2844&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;16&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;13.846&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;32.82&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;1.3425925925925924E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;2906&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;15&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;14.871&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;36.01&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;1.5856481481481484E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 :num=&quot;2969&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;15&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;16.152999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;39.97&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;1.8055555555555558E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3063&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;15&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17.178999999999998&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;43.85&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;2.0601851851851853E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3219&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;16&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17.692&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;47.46&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;2.2916666666666667E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3281&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;16&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17.692&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;48.37&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;2.5462962962962961E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3406&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17.434999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;49.49&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;2.7893518518518523E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3500&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17.434999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;50.85&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 :num=&quot;3.020833333333333E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3563&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17.692&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;52.53&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;3.2754629629629628E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3656&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;17&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18.204000000000001&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;55.46&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;3.5300925925925922E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3781&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18.974&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;59.78&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;3.7962962962962964E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3875&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18.974&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;61.27&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;4.0509259259259258E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;3969&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19.23&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;63.6&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;4.3171296296296299E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4063&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19.742999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;66.85&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 tyle='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;4.5370370370370367E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4094&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19.998999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;68.23&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;4.8032407407407408E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4188&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19.998999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;69.8&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;5.0462962962962963E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4344&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;20.256&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;73.33&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;5.3124999999999997E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4406&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.92&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19.742999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;72.49&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;5.6018518518518512E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4531&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19.742999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;74.55&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;5.8217592592592599E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4625&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;19&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;20.256&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 :num=&quot;78.07&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;6.0069444444444454E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4906&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;21.024999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;85.96&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;6.2500000000000015E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4875&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;20.768000000000001&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;84.37&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;6.4930555555555556E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;4969&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;21.024999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;87.06&quot;&gt;&lt;/td&gt; &lt;/tr&gt; &lt;tr height=17 style='height:12.75pt'&gt; &lt;td class=xl22 x:num=&quot;6.736111111111111E-5&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;5094&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;0&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;18&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;00.9&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;21.280999999999999&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;100&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;81&quot;&gt;&lt;/td&gt; &lt;td class=xl15 x:num=&quot;90.34&quot;&gt;&lt;/td&gt; &lt;/tr&gt;&lt;/table&gt;&lt;/body&gt;&lt;/html&gt;"></object></div>
Jeebus that was a pain to do.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
