fuel trim
anchew02
59
May 17, 2011
maricopa, Arizona
so ive been driving my car for a couple days now after chip and 650 injector install. my lt fuel trims have been decreasing slowly and as of now it is 87.5%.
question is does this mean im running really rich?
Running 43psi via AFPR? The lower MAF hack will give you a little more room for airflow metering purposes before you run out, and a result will be to run slightly leaner. Hopefully, this will bring your LT trims back up to normal.
Your low trim isnt dropping because your fuel pressure more then likely your injectors just require a bit less deadtime then the norm. Or the 20 year old crappy maf is not reading right they really are a pos....
As I said before to you should only be needing to make fp adjadjustments base off you high fuel trim which was perfect from my understanding when you Pm,d me
. An haking your maf is only gonna throw thing off more since no changes where made in the maf comp. For the chip...
