Fuel Return line to AFPR NEED HELP!
skandel11
49
Feb 26, 2008
Quakertown, Pennsylvania
what line is the fuel return line that you connect to the bottom of the fpr? i just bought a FPR kit from extreme psi the A1000 kit. also does anyone have a picture of where this line is stock and then on the new fpr? it would be a great help im trying to put this in today!
The line stock on my 2g comes up the firewall behind the intake manifold in the direction of the cam gears. It is a hard line that has about a foot of 3/8' fuel line connected with it at the end that will run to the bottom nipple of your new FPR. Hope this helps. It may be different considering my 2g is auto....
The stock return line is circled in green (it's the one with the hose clamp on it). As gsxrtalon said, it is a hard line. You will have to run some fuel line (which you can get at your local auto store - looks like vacuum line, but is reinforced with some threading) from the nipple on the bottom of your AFPR to that hard line. And then just clamp it down really good.
  • Wanted 6 bolt NT water pipe
    • chrisman287
