Fuel Return Advice.
Grescht
166
Apr 1, 2008
New Kent, Virginia
Hey guys. Got a question for ya on what would be my best option. Im upgrading my fuel system. i'm running a 044 inline with a custom in-tank pickup. Because of the bulkhead that is now in the top of my tank assembly for the feed line, the metal part of the return line had to get cut. Now im trying to figure out a way to connect a hose to that metal line that pokes out the tank assembly. Could i just run some hose and clamp it? will that not work because there is no lip on the end of the piece of metal?(now) Is there something I can attach to it to better serve a clamp? or am i going to have to drill it out and make new fittings with an fittings? How much pressure does the return see anyway?
Shoot me some ideas on how to hook up my return line. I was planning on running 6an line to it.
It has virtually no pressure in the line, you can get away with just using a hose clamp.
