fuel regulator?
Well as you know you suppost to be running rich rather than Stoich or lean..., but if your car is running really rich because of your mods, then a SAFC will be a better choice, but then again the best option will be to get both the SAFC and a FPR so you can tune everything the right way...
thats what i was expecting, adress the real problem first, the fuel pressure. what does anyone think of the cheap apc afpr. anyone have it
Yea, I use that one. Actually I use the cosmo racing FPR, which I believe to be the same as an OBX. I hooked mine up off of the fuel rail though. I drilled and tapped a hacked up stock FPR fitting for 1/8" NPT. Then using some home depot brass goodness, I rigged it on there, it's doin a kicass job.
