420A Fuel questions
lxeclipsegsx
66
Dec 6, 2005
Delano, California
Here is what happen i finally built my engine car wont start i forgot the fuel injectors i have aren't good anymore. i have a fully built GS planning to boost 8psi because the lack of money to upgrade my fuel system.
i was gonna go with my stock injectors, 255 fuel pump, and FMU 12:1 to boost those 8pounds of boost.
but now i'm force to buy new injectors dont know what size to go with i'm thinking of going bigger but then that changes everything i would be force to buy a SAFC dont know what set up to go with something cheap any help thank you.
550cc+walbro 255 fuel pump+SAFC?
Ok, you definetly need the walbro.
If you go with bigger injectors, you're going to need at least an sfmu to control them.
The bad news, you're probably gonna spend around $400 on an sfmu and fuel lines and fittings, the good news is you don't need an SAFC. The other bad news is, you can't go bigger than 440's/450's without an SAFC, and you may still need it for 440's/450's, however, if you go for 330's or 310's you will not need an safc and will be fine with just an sfmu. Some people have been able to get their car to run right with 440's or 450 dsm injectors (with a resistor pack) without an safc, but others have not, just something to consider when you make your decision
