OBX Fuel Rail Installation Questions
inferno617
50
Jan 29, 2006
Southampton, Pennsylvania
I got my hands on a obx fuel rail, with no instructions and I get the gist of how to put it on, but it came with extras parts. Does anyone have instructions on what the rest of these parts are for? Or if there are some pics of this product installed. I do not want any people telling me obx is crap like i see in other threads, i just want something that will help me with what i have to work with.
Picture of the parts in question would help. Maybe they sent o-rings for the injectors, FPR, new line from the filter to rail................
You know that OBX is cr.............no, no j/k ;)
Yeah, pics or descriptions are going to help us. Pics prefered.
MB
cimotorsports has the same exact thing that i would show you if i had a working camera. its the piece to the far left that is held in with two longer screws and uses the o-ring or you can just block it of with the plug provided. then there are 4 tiny screws w/ lock washers that do not go into anything. it looks like something is suppose to attach to the back of the block.
OBX Fuel Rail 95-99 Eclipse/Talon 420a
Hmm, I see what you mean with the screws. There are no corresponding holes? Or do you mean by back of "block" you are talking about the rail itself?
MB
I'm talking about the little block on the one end. I'm not sure what it is for because it has an opening in the back of it. I know the pipe goes on the front for a return fuel line.
I know in the stock fuel rails the fpr is pressed into the rail, I'm guessing that is what i have to do on the backside. or is there an aftermarket that will go in there?
ok so i am getting a rough idea of what to do now. I got the stock FPR in the hole right now. should I use this with a vacuum regulator attached to the line or is there some kind of upgrade fpr that takes place of the stock?
I had that piece in my garage for years and never had the motiviation to find out what it was for. I had already had an aftermarket FPR attached at the end of it.
When you find out I am all ears. I could see a way, back then, to attach my oem fpr to it. Not that I needed to given my prior comment but I was curious.
Add a picture of what you have done, especially if it works. I admit I've not searched to see if anyone else has it done yet but my interest is peaked so add pics!!
