95TalonOwner
- 1,311
- 27
- Oct 18, 2005
Milwaukee,
Wisconsin
I am about to get my 2.2 stroker and built head. I am going to go megasquirt but for the time being I have these 450cc injectors from my old 90 turbo laser. I am getting a wideband and I am going to be going sort of a crude way of tuning until I get megasquirt and I want to know what you guys think.
Right now while I'm breaking everything in I just plan on putting the 450s in. What I wanted to know is that is there a way to lower the fuel pressure enough to where it will still idle fine with the larger injectors. I have the 12:1 fuel pressure riser that came with my hahn kit which is what I will be using for the crude tuning for now. Should I just eliminate my stock fpr on the rail and use the hahn one only in order to drop the pressure?
I don't even know if any of this will work but I figured I'd try and ask. I just don't want lack of fuel to be an issue with my new motor since I spent so much on it.
Also, is there a kevlar timing belt available for the 420A because I'm having a hard time finding one.
. And while your one rule is unwritten?!..... Well why dont you ####in write it then! Go ahead delete me, ive gotten better advise from dead dogs. No point in talking to you or anything, all your good for is bashing the people who know less than you just to make yourself feel better. But hey i guess that what little penis's do....
