fuel pump wont turn on
rayrayx11
165
Aug 8, 2008
riverside, Rhode Island
installed dsmlink fuel pump rewire and 190 wally. havent ran the car in months. i finished the install. put some good gas in. and nothing. all my gauges turn on but im not hearing the pump turn on. i have power going to the relay. i double checked all my wiring. what should i check next.
Don't have an answer for you but the same thing happened to me. I still haven't found the problem but I have my pump hardwired to a switch. I consider it a kill switch.
Subscribed, hopefully there's somebody that knows what we've missed to check.
Sent from my Atrix 4G using Tapatalk
Are you sure you have the relay wires in the correct position? 12v=30 Ground=85 power to fuel pump=87 Stock 12v wire from car=86
If you have a test light ground it and check 86 for voltage then check 87. The car should still crank without the fuel pump running.
Found the problem? Please don't tell me the reason the car wouldn't crank isn't because you weren't pressing the clutch when swinging the key.:ohdamn:
