2G Fuel pump wiring harness
GSX_beast
51
Jan 24, 2012
Myrtle Beach, South Carolina
I'm pretty sure I accidentally threw away the little wiring harness that connects the fuel pump to the bulkhead. Is there any way to buy or new one? Can I make a new one somehow? I have a 2g gsx.
97 no abs. I ordered a walbro replacement harness and I just picked up some small female blade connectors. I'm wondering if I should fabricate some kind of rubber insulator since im missing the factory plug.
Gold plated blade connectors, should have better connectivity than stock. And I'm doing the pump rewire also.
So you don't have the connector coming through the grommet to the fuel tank area? Or you don't have the harness that would connect that to the fuel pump and gauge unit?
The OEM part number for the fuel pump/gauge unit harness is MR243733 for a non-ABS '97 GSX. Of course, if you're redoing everything anyways, none of this really matters.
