fuel pump options
Texas gst
225
Oct 17, 2010
Lubbock, Texas
I'm wanting to get a 190 or maybe 255 fuel pump. I was wondering if these are stock on any cars? What I'm curious for, is that I work for a national repair facility so I can get great deals on parts from Advance, O'reilly's, Autozone, etc. Is there a vehicle that I can get one for that is the same? Easily stated, can I get a fuel pump for a 99 mustang gt (or whatever) that is the same?:hmm:
IDK if they come stock in any car. Maybe the mustangs, but wally fuel pumps are relativity cheap in the fuel pump world. 99 bucks for a 255 with install kit is pretty good.
An alternative is using either the evo 8-9 fuel pump or utilizing a Supra TT fuel pump. Both have been used by people on here with their DSMs.
goodluck
-Lawrence
Will I HAVE to have a fpr with the 255? I'm about to put on an EvoIII in about a week, and down the road I am going to get 650-660 injectors. That's why I was leaning towards a 190, but if a fpr is not needed for this setup, than I guess I should just go with the 255. I think I'll do the rewire when I put the turbo on, just to be safe for now. I'm only going to run about 14 psi, as I have read a lot that it will be safe with my stock fuel system.
The stock Denso 1g Fuel Pump flows 102 LPH at 43 psi with 12.5 volts. (Denso 195130-0510)
The stock Denso 2g Fuel Pump flows 130 LPH at 43 psi with 12.5 volts. (Denso 195130-2760)
The stock Denso EVO 8 Fuel Pump flows 160 LPH at 43 psi with 12.5 volts. (Denso 195130-3360)
The Walbro 190 Fuel Pump flows 168 LPH at 43 psi with 12.5 volts. (Walbro GSS-250)
The Walbro 255 Fuel Pump flows 230 LPH at 43 psi with 12.5 volts. (Walbro GSS-317)
The Walbro 255hp Fuel Pump flows 233 LPH at 43 psi with 12.5 volts. (Walbro GSS-342)
The Denso 260 LPH Supra Fuel Pump flows 258 LPH at 43 psi with 12.5 volts. (Denso 195130-1020)
Info taken from Road Race Engineering.
Hope this helps!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
