Fuel pump hose
Butters576
Jun 19, 2015
Lawrence, Michigan
I have a 1G FWD Talon and I'm having trouble finding the hose that connects the fuel pump to the fuel line and where can I get one thanks.
You can't get a "factory" type replacment that I'm aware of. You have a few options:
-Have a custom hose made at a hose shop. You'll need hose with a dual sided female 14x1.5 inverted flare fittings. Basically, a hose that mirrors the factory one.
-Convert your fuel pump hangar to AN fittings and use an adapter on the stock hard line: http://www.dsmtuners.com/threads/qu...ck-hard-fuel-feed-line.440736/#post-153162147
-If you're in a pinch, you can do something like this, however, I wouldn't recommend this as a permanent fix: http://www.dsmtuners.com/threads/fuel-pump-install-write-up-via-cuting-fuel-hose.339463/
