Fuel Pump Fuse on a 2nd Gen
geddytrams
Jan 15, 2006
Westminster, Maryland
I'm posting this because I feel that it's necessary for this information to be posted for anyone else who runs into the same problems as me. Everyone seems to know that the fuel pump fuse is located on or near the positive terminal on a 1st gen talon/eclipse, but no one seems to know where the fuel pump fuse is located on the 2nd gen. I've looked through every related thread, but NO ONE seems to know where it is.
So this is a call for help. I need to know, and i'm sure someone else will in the future. If anyone knows where the fuse for the fuel pump on the 2nd gen talon/eclipse, post a response. thanks to anyone who can help
First of all, all 2g's have a fuel pump relay (on the 95, however, it and the MFI relay are in the same box with an 8 pin connector).
On the 2.0 NT, the relay power comes from a 30A fusable link in the engine fusebox which is shared with most of the other engine electrical.
On the 2.0 turbo and 2.4, the power comes through the ignition switch from a 30A fusable link in the engine fusebox which also supplies everything else on the ignition switch.
