Fuel pump and clutch problems...
GSX1stgen
Mar 13, 2004
Vancouver, Washington
Just actually recived my car today, and no start, turns over fine,it is just not getting any fuel, so I replaced fuel pump with Venom high volume (was planning on anyway), replaced fuel filter.... still no fuel, then checked power, not getting any to pump, like i said i am very green with these cars and need help... where is the ecu located? and the relay next to it controls the fuel pump?
>The previous owner said he had the car sitting for a while, would go out once a week and start it up and the last time he went to start it nothing happend......
it is also having clutch engadgement issues... it has Brand New clutch M/C and slave, but still having problems engadging, you cant put it in gear! i do know he had the cluch assy completly torn apart and put new parts in>>> are there any adjustments i should try before replaceing all the parts again? possibly clutch fork or pivot bushing (fulcrom)?
ANY AND ALL HELP IS GREATLY APRICIATED!! need to try and get on road by this monday... ahhh having a little buyers remorse :confused:
There is a relay for the fuel pump under the hood. It is near the battery on the firewall.
You can adjust the clutch pedal by loosening the nut on the threaded rod that comes through the firewall. It is above the gas pedal. From the sound of it you need to thread it out of the pedal (more threads toward the firewall).
